Brief Description: Seat cushions and baggage compartment
Re-installed the Velcro strips at the front of the seat. Drilled out some hinge rivets and installed some contour washers on the Velcro with rivets into the hinge and spar.
Installed the Velcro strips for the back cushion using contour washers and rivets. Since the strips don't need to be removed, the rivets will be fine instead of screws.
Finished putting snap holes in the baggage material. The material is synthetic, so I found that melting a hole using a small soldering iron worked better than using a punch. It also results in less fraying around the hole.
Drilled holes in the longerons and the back cross channel for the snap studs. I found riveting the stud in place along the thicker longerons worked well. Also used rivets on the thinner cross channel instead of sheet metal screws.
Front Velcro secured with contour washers and rivets
